Wasn't long ago they were there and I could look up PN's for engine seals etc. and see if I could still find them. Bike is a 1970 T250II Hustler (the high pipe srambler type bike).
Any known still active sites that would go back to 1970 so I can try to find seals and bearings for a crank rebuild.
Looks like Bill Bune requires the parts along with the crank when doing a build. I'd strip first as I expect the bearings are still very good and just need seals, but I need to find them first.
Any leads on good seal kits would also be welcome.
thanks.
Can't seem to find online parts fiches that go back to 1970
2004 HD 1200C
2001 Duc M900
2001 Hon XR650L
1994 HD Heritage
1978 Hon CB750 w/ sidecar
1977 Guzzi 850 LeMans
1976 Hon CB750K
1965 Hon 305
1973 Nort 850
1971 Tri Trophy 650
1970 Hon CT 90
1970 Tri Tiger 650
1970 Suz T250
1973 Hon Z50
1971 Yam RT1
2001 Duc M900
2001 Hon XR650L
1994 HD Heritage
1976 Hon CB750K
1965 Hon 305
1973 Nort 850
1971 Tri Trophy 650
1970 Hon CT 90
1970 Tri Tiger 650
1970 Suz T250
1973 Hon Z50
1971 Yam RT1
Re: Can't seem to find online parts fiches that go back to 1
Dealers update their software from time to time, so the list of parts inventory links also changes.
Alpha Sports tends to have high prices.
They usually have the parts diagram but often don't list numbers for NLA parts.
http://www.alpha-sports.com/suzuki_parts.htm
Partzilla has good prices but their parts diagram can be a bit screwy.
They list the T250II & T250R/J as 1972 models.
http://www.partzilla.com/parts/search/S ... parts.html
Paul Miller has the set of crank seals on eBay for $69.
http://www.ebay.com/itm/Suzuki-T250-T35 ... 1390385020
A printed parts manual can make it easier to get part numbers & chase down NLA parts.
They typically are available via eBay.
thanks, didn't think about trying to find a parts list to download off the net. Got my service manual that way plus some other stuff. Will get to searchin. Thanks for the other leads.
2004 HD 1200C
2001 Duc M900
2001 Hon XR650L
1994 HD Heritage
1976 Hon CB750K
1965 Hon 305
1973 Nort 850
1971 Tri Trophy 650
1970 Hon CT 90
1970 Tri Tiger 650
1970 Suz T250
1973 Hon Z50
1971 Yam RT1
2001 Duc M900
2001 Hon XR650L
1994 HD Heritage
1976 Hon CB750K
1965 Hon 305
1973 Nort 850
1971 Tri Trophy 650
1970 Hon CT 90
1970 Tri Tiger 650
1970 Suz T250
1973 Hon Z50
1971 Yam RT1
The early gear indicator switches were made out of aluminum and in my opinion fer superior to the later plastic ones. The plastic ones have been known to crack. I hope that's not your case as there is no fix. Used ones do show up on eBay though + it doesn't have to be off a 380. The GT550 and GT750 use the exact same part. The other bikes never see the '6'.
EDIT! I put this in the wrong place. can't delete. Sorry
