Carburetor spec discrepancy for GT750M models
mfrias2nd
Country: U.S
Suzuki 2-Strokes: '75 GT750, '73 Norton...yeah I know, not here
Post by mfrias2nd »
Hi everyone, Just thought I'd contribute because I came across this discrepancy with some specs I've pulled up. In tearing down my carbs on my 1975 M model I noticed the needle was on the 4th down position. I pulled the specs and the following pulled up.
Haynes States 3rd position for M model
Suzuki Carb manual (although specifically states L model) states 3rd position
whatever spec is posted below in image states 4th.
Anyone know the true position for the M model?
mfrias2nd
Country: U.S
Re: Carburetor spec discrepancy for GT750M models
Post by mfrias2nd »
As you can see this is off the Haynes Manual which shows a Circlip position discrepancy from above. can anyone clarify this?
Carb specs are listed in service bulletins. 71-75 specs are in Specification-6. 76 specs are in Specification-8.
76 specs has a footnote about the jet needle change.
See: http://www.ozebook.com/compendium/techb ... %206-9.pdf
mfrias2nd
Country: U.S
Post by mfrias2nd »
Thanks for another reference Jabcb... does anyone know about the above image where it states 4DN18-4? This is a richer setting. Would this spec be for any upgrade? So far 3 out of 4 state 3rd pos. I'm curious where this 4th pos comes from?
:) My "A" model happily running on the 4th notch,never tried another setting,only thing I've done is give carby's a good clean,new needle & seats +1 new float, & bought the excellent DVD on the Vacuum Carbs,by Bluesmokebaz on Ebay.. :up:
