Guys,
I read this post. a lot of effort put on this one.
Ccan someone sumarize the seal and O ring size needed?
Then add MFG and possible supplier.
I don't think anyone has a kit yet (due ti back order, long lead times, slow post)
but if I had the sizes and mfg or supplier I can try to get these from USA.
T500 oil pump repair problem
Re: T500 oil pump repair problem
73 Kawasaki H1 500
73 Kawasaki H1 500
T500 pump disassembled:
Here is the list of sources I used:
1.8x10 o-ring
http://www.theoringstore.com/index.php? ... s_id=18427
2x12.5 o-ring
http://www.theoringstore.com/index.php? ... ts_id=1971
2x20 o-ring (used instead of 1.8x20 o-ring)
http://www.theoringstore.com/index.php? ... ts_id=1942
9.5x16x4 oil seal (may still be out of stock at this store) (manufacturer: Winderosa)
http://www.mfgsupply.com/501415.html
8x14x4 oil seal
http://www.bocabearings.com/bearing-inv ... MS8X14X4TC
The 8x14x4 oil seal didn't seat properly on my pump. Will be using an inch-sized oil seal instead.
1.8x10 o-ring
2x12.5 o-ring
8x14x4 oil seal
- Country: Ontario, Canada
- Suzuki 2-Strokes: B100P,T200, 68,70,74 T500,GS650G DL1000
I finally got an email from Winderosa, they are the US distributor for the 9.5x16x4 seal. They do not manufacture the seal themselves, they supply retailers such as MFG, Amazon, etc. The seal is imported from Taiwan. They now have stock so my order should go through my local retailer.. Hopefully, I should have the seals in about a week. MFG should also get a new batch now that Winderosa has supply. My original order for the seals was placed on Jan 23rd, it has taken this long for Winderosa to restock. I have all the other O rings and the other oil seal for an initial supply of 30 kits.
Fred
Fred
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
Received the 9.5x16x4 oil seals today, I now have everything for the official "T500 Oil Pump Seal Kit'. Will update shortly on cost and shipping.
Cheers....Fred
Cheers....Fred
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
The T500 oil pump kit is now available under the "Services" category.
Cheers....Fred
Cheers....Fred
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
Weather is starting to get nice again so I started working on the T500 oil pump again.
Used the Harwal oil seal (.313" x .563" x .25") instead of the the standard-sized top seal (8mm x 14mm x 4mm).
Had no problem with the seal spinning. Seal is a little thicker so I had to use a gasket under the top cover.
So my oil pump problem is solved. No leaks & its pumping oil in all the lines.
