Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sun Jun 07, 2020 3:36 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: T575 Steam Triple
PostPosted: Wed Aug 21, 2019 1:49 pm
Online
Suzuki 2-Strokes: GT750 hybrids (x2) VJ23A RGV500 TS185 R250
rear / upper adjustable engine mounts in place........
and with a bit of tweaking, the chain run is good, rear wheel axle, swing arm pivot and drive sprocket centres align, and my trusty spirit level says the motor is -
level :up:
_________________
Garry
I'm addicted to brake fluid, but I can stop anytime.
Top
 Profile
PostPosted: Thu Aug 22, 2019 6:23 am
Offline
Country: england
looks good garry :up: i actually thought you'd given up with this build and concentrating with the benelli/triumph :D keep up the good work and keep upsetting the purists :P
_________________
Top
 Profile
PostPosted: Thu Aug 22, 2019 11:53 am
Offline
Country: England, UK
Nice engine mounts. Just thought you might want to turn the rectifier/regulator up the other way to avoid water being funnelled in. I know it shouldn't leak but sods law says.....
Top
 Profile
PostPosted: Thu Sep 05, 2019 3:59 am
Online
the lower rear engine bushes - that replace the original rubber ones - and the anti-crush tube.........
and in situ..............
_________________
Garry
Top
 Profile
PostPosted: Thu Dec 19, 2019 7:03 am
Online
_________________
Garry
Top
 Profile
PostPosted: Thu Dec 19, 2019 2:55 pm
Offline
Looking good @Gary55.
Do we have an estimated time to completion?
Top
 Profile
PostPosted: Fri Dec 20, 2019 5:03 am
Online
tz375 wrote:
Looking good @Gary55. Thanks :up:
Hoping to have it completed by March 2020.
Motor being rebuilt now, bike goes in for bespoke 3-1 exhaust system fitting in January.
Just the electrics to sort meantime (new charging system etc).
_________________
Garry
Top
 Profile
PostPosted: Fri Dec 20, 2019 5:05 am
Online
then it may need paint....................... :D
_________________
Garry
Top
 Profile
PostPosted: Wed Jan 01, 2020 11:04 am
Online
today's work - drilling and filing one of the original T595 fairing / mirror support arms.
_________________
Garry
Top
 Profile
PostPosted: Wed Jan 08, 2020 8:19 pm
Offline
Suzuki 2-Strokes: RGV RGV RGV RGV ......
garry55 wrote:
Unable to see any of your previous pics, but this one shows a great looking project.
Would have never thought of that frame working so good with a GT750 engine. :up:
After looking at the front end, I started wondering about those calipers....(Triumph/Nissin)
They look the same as TZ250 3YL/4DP which have a 83mm spacing?....are they 83mm or the typical 90mm as in GSXR
_________________
MY TWO STROKE ADDICTION
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
GT 750 J....sold.....
GT 750 long term cafe project
SX-R 800
KD 80
JR 50
RZV 500 R
Top
 Profile
PostPosted: Sun Jan 12, 2020 9:43 am
Online
both modified mirror mounts fitted and my 3rd attempt at modifying a T595 nose fairing to suit..............
_________________
Garry
Top
 Profile
PostPosted: Sun Jan 12, 2020 9:47 am
Online
under-seat bits and pieces (2T oil tank, battery, fuse box, relays, coolant expansion tank and battery charger fly-leads) all in place. Battery sits in it's own space under the 2T oil tank (see post below), which is why you can't see it.
_________________
Garry
Top
 Profile
PostPosted: Sun Jan 12, 2020 9:57 am
Online
As I am not running the electric starter motor option for the Steam Triple motor, it means I can run a much smaller (lighter) battery.........
Triumph T595 on the left, RGV250 on the right.
There was nowhere to mount the RGV battery in the T595's battery compartment, so I purchased a VJ21 RGV250 battery box............
and set about cutting off all the mountings...........
leaving only the tabs for the securing strap to attach to. Snug fit...........
Then I drilled the floor of the T595 battery compartment to accept a pair of rubber mounts........
and here it is, bolted in place and looking lost...........
this modification allowed me to cut 1" off the top of the T595's battery compartment to allow the Aprilia RS125 2T oil tank to fit above it.
_________________
Garry
Top
 Profile
PostPosted: Sun Jan 12, 2020 12:47 pm
Offline
World Superbike
Suzuki 2-Strokes: 2 x GT550s GT750, T200, TC200
Coming on nicely. :up:
_________________
Top
 Profile
PostPosted: Sun Jan 12, 2020 2:15 pm
Offline
A truly fascinating project, Garry :up: I love to see your updates and solutions/engineering to get it developed.
Top
 Profile
Who is online
Users browsing this forum: garry55 and 10 guests
Jump to:
cron
Suzuki2Strokes.com
