GT 500 tacho drive from oil pump
- Country: United Kingdom
- Suzuki 2-Strokes: GT500B 1977
Hi
I wonder if anyone can advise. My tacho gets to about 7k then it starts to play up - sometimes it drops then wildly increases. The bike runs well all through the rev range its just that this is not represented in the rev counter. I assumed the tacho was at fault so I bought a new one but it hasn't cured the problem. I've traced the cable down to the oil pump so I assume the fault lies here although it could be the cable. Any idea what could be wrong? Any guidance would be most welcome.
- Country: us
Re: GT 500 tacho drive from oil pump
I wouldn't be to concerned, my GT500 starts doing it around 3k rpm, and my speedo does it around 50 mph and starts jumping around.
The way I understand is the liquid in the meters between the cable and the needle are sealed in a sort of cup, if some liquid escapes it causes the meter needles to jump around and not spin correctly. You may want to oil the cable to see if it fixes it, but to fix the meters you need to open them and replace the liquid.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
Thanks Karl.
I bought a new meter and it still does it. Do u know the type of liquid within the meter itself - is it a thin oil perhaps ?
- Country: us
If you look at oldjapanesebikes.com resources under new production GT750J gauge shells. He lists a special silicone fluid from radio control hobby car shop. but advises caution that the process if not done correctly can render gauges useless.
Many of my gauges don't work perfect, which I believe many from that era do not.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
- joolstacho
- Country: Australia
I don't think I've done a GT one, but others that I've worked on don't have any fluid in them apart from very small amounts for lubrication.
They work using magnetism- a spinning magnet attracts the needle assembly, and the faster it spins the more the magnetic attraction, so the needle rises. The clearances are close, quite possibly worn bushings could cause problems.
But you've tried a new (?) tacho, so assuming it is new the problem wouldn't be the tacho head itself.
The ones I've encountered were fixed by flushing out the mechanisms with Meths - the old oil gets sticky. I'd imagine loss of magnetism could be an issue also.
Is there an expert in the house?
- Country: us
I never attempted gauge repair, but like I said, according to Ian at oldjapanesebikes, the GT750 uses silicone fluid, and no mention of magnetism. If the GT750 uses fluid I would think the other models would be similar.joolstacho wrote: ↑Fri Jan 29, 2021 4:51 pm I don't think I've done a GT one, but others that I've worked on don't have any fluid in them apart from very small amounts for lubrication.
But it does say later models are different, so maybe later ones are magnetic. He does refer to a bell which may be a magnetic, but refers to the fluid damper to stop needle bounce.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
- joolstacho
Quote:
Working Principle of Tachometer:
An Electric Tachometer works on the principle of relative motion between the magnetic field and shaft of the coupled device. The motor of tachometer works as a generator, i.e. it produces the voltage based on the velocity of the shaft.
(The fluid is just the lubrication).
- Suzuki 2-Strokes: 1966 T20
The oil is actually for damping. The drive to the (magnetic) speedo/rev counter heads is via a long flexible cable. Even in good condition this does not always provide a completely smooth feed to the gauge. At some rpm's this can spin a bit jerkily and the speed at the end varies slightly in rotation. If the mechanism is not properly damped then the needle responds accordingly. The damping is easy to check. If you rotate the needle it should fall back quite slowly. No oil and it slams back quickly. The oil is in a small cup on the lower down on the shaft so not obvious.
I could put some pics up if people are interested as I have two T20 clocks in bits, one of which has lost its oil.
Keith
Keith
1927 Scott 3 Speed Super Squirrel
1948 Scott Flying Squirrel
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
Definately NO 4 strokes
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
- Country: us
This is why I like this forum, there is plenty I can learn still.
How do you add fluid to the sealed cup, I have an old speedo that I may open and try to learn.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
I have never done it, I'm afraid. However, I am aware it is possible. When rebuilding my T20 speedo/tach I just picked heads with good damping.
I'm sure others will advise
Keith
Keith
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
Hi Ian T,
The first step I would take would be to remove the speedo cable inner. Flush the outer with a solvent, clean the inner of dried congealed oil. Re-lube with a light oil and re-install. The issue you describe can be caused by an inner cable "gripping and then slipping" due to the old lubrication getting a bit gummy.
Wow - great advice guys, thanks.
Before I delve into the tacho I’ve ordered a new tacho cable so will report back once it’s installed and tested.
Cheers all.
Cheers all.
The cable change hasn't made a difference - needle still bouncing all over the place. Keith - if you are able to post a few pics of where fluid is found within the 'cups' that would be great.
Many thanks
Many thanks
Hopefully clear on the attached. As I understand it, the silicone oil is contained in that small tapered cup above the coil spring which sits just below the needle and frame. Not to be confused with the main magnet drive bowl further down. As said before, I've never added any oil so cannot help with the process or the recommended oil. Lots of clocks show a damp looking area where the original oil has oozed out. Don't store them upside down when off the bike!
Getting the bezel off without damaging it is usually very hard. If I were in your position I would be tempted to send it to an expert. I only pulled mine to bits as it had a crushed bezel and I managed to get some dismantled spares to build a good one.
Keith
Keith
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
Thanks Keith - Good advice. Do you know of any UK based specialists who could sort?
