X-6 ugly clutch
barko1
X-6 ugly clutch
Post by barko1 »
I was going to ask a question about my recently acquired X-6 and the clutch. The PO (or sinful bastard) said the clutch was "stuck" :roll: But I think the answer is a new clutch, this is one nasty, rusty, diseased unit.
Here's another look :(
John I aka Barko1
Concours 1400
DR650
KDX200
Norton Commando 850
Suzuki X-6 Hustler Scrambler (in pieces)
Suzuki GT750 Buffalo (TBD)
cpt137
Re: X-6 ugly clutch
Post by cpt137 »
well, he was right.
wvc
Re: X-6 ugly clutch
Post by wvc »
thats one ugly clutch. i would be worried what the rest of the bottom end of the motor looked like.
4 other 76 GT500's
1.5 GT550's
4 GT380's
5 T500's (72-75 models)
4 GT750's
barko1
Re: X-6 ugly clutch
Post by barko1 »
wvc wrote:thats one ugly clutch. i would be worried what the rest of the bottom end of the motor looked like.
Is there an easy way to check?
John I aka Barko1
Concours 1400
DR650
KDX200
Norton Commando 850
Re: X-6 ugly clutch
barko1 wrote:Is there an easy way to check?
Easy is a relative term I'm afraid :? I suspect your only option is to crack the cases.
Looking at the photo, while it doesn't look great, it also is a little bit hopeful as the corrosion seems largely localised to the clutch basket. You won't know till you have it apart further. On mine, I did experiment with some Evap-o-rust which does a nice job of de-rusting, but the gear teeth faces were pitted so I ended up replacing almost everything except the cases :cry:
barko1
Re: X-6 ugly clutch
Post by barko1 »
It does seem mostly limited to the clutch basket so I will remain optimistic. I think my plan will be to take care of what I can do simply, fix the clutch, replace cables, plugs, carbs are clean, then throw some fresh gas in her and see what happens. Oh I guess I will have to learn about points and such!
John I aka Barko1
Concours 1400
DR650
KDX200
Norton Commando 850
