My other bikes....even some non suzuki 2 strokes
Photos that don't really fit in the above catagories.
busa1300
Suzuki 2-Strokes: RGV RGV RGV RGV ......
Re: My other bikes....even some non suzuki 2 strokes
Post by busa1300 »
Alan H wrote:You need a clear fairing so the frame can be seen. It's a work of art, is that.
Thank :up:
The biggest problem with the modern era strokers is the bikes need fairings to hide everything.
As they developed more HP they also became quite complicated.
Water hoses. radiators, oil lines, fuel lines, powervalve cables, throttle cables, choke cables, wiring for air solenoids, and extra hoses for air and vacuum needs.... You can barely see the motor with all the crap necessary :cry:
Although Suzuki did build the VJ21 as a standard type bike for Japan.....but it is still pretty busy looking under the tank compared to the simplicity of an aircooled stroker.
I had thought long and hard about building it as a cafe racer instead of going with original paint and bodywork.....still not sure if I made the right choice.
____________________________________________________________________________________________________
MY TWO STROKE ADDICTION
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
GT 750 J....sold.....
SX-R 800
KD 80
JR 50
RZV 500 R
https://www.youtube.com/@wedgehorsepower9869/videos
It's your bike, so your choice is ALWAYS the right choice.
busa1300
Post by busa1300 »
Alan H wrote:It's your bike, so your choice is ALWAYS the right choice.
The VJ21 SP project will be on hold for a while, until life gets back to normal around here.
Which will give me more time to second guess my decisions :mrgreen:
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
garry55
Post by garry55 »
I had a TV250 Wolf. Never liked the seat unit, so I modified it to take a Mito unit. The motor was tuned to "naughty" spec and it's the bike I set my 250 cc fastest lap of Cadwell Park on.
for a modern water cooled twin it looks remarkably uncluttered under the tank.
Garry
busa1300
Post by busa1300 »
Looks like a fun bike Gary.
I had started to collect some Wolf gauges and had been searching for the headlight and brackets.....then decided to keep it with full bodywork.
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
garry55
Post by garry55 »
It is a much more comfortable ride with the higher handlebars. The single disc is more than adequate too (with race pads fitted).
It weighed next-to-nothing and kicked out 58bhp at the rear wheel (on the dyno).
One of the few bikes I wish I hadn't sold on.
You have got me looking for another now.................... :D
Garry
busa1300
Post by busa1300 »
Decided stock bodywork
Finishing up paint work, and collecting bits to get the engine back together for the VJ21-SP....but not much to show for all the time that has passed.
Test fitting Lectrons for cables
Veronesi intakes to adapt the 38mm Lectrons in a upright position
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
Hush
Country: New Zealand
Suzuki 2-Strokes: 74 GT550 L 73 GT250K
Post by Hush »
I rebuilt a very dead and neglected GT250K as a run-up to doing my present GT550L and I learned heaps from the little beauty.
busa1300
Post by busa1300 »
Hush wrote: Fri Nov 13, 2020 1:38 am I rebuilt a very dead and neglected GT250K as a run-up to doing my present GT550L and I learned heaps from the little beauty.
That is a very nice looking 250, from a time when two stroke engines had beauty and were part of the bikes style.
An update on my Suzuki two stroke project.
Parts to build the 300 bigbore
After finally finding and collecting the parts I needed....it was time to fit them all together....
I made up my throttle cables, to work with the distribution box and the TPS, so I can have a 3D ignition map.
Also was able to adapt the factory choke cables to the Lectrons so I can control them from the handlebar.
Then I needed to work on the wiring and new ignition....
I started by taking the box and separating the wires to make it make it easier to hook up
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
garry55
Post by garry55 »
what is the difference between the Dyna DC11-1, DC11-2, DC12-1 and DC12-2 coil packs?
Garry
busa1300
Post by busa1300 »
I looked on the website and it is a bit confusing.
The DC12-1 looks like a pair of single output coils
DC12-2 is one single output coil
DC11-1 is a pair of dual output coils.....
I think that is how it goes....???? but definitely not 100% sure on any of it.
You still have the VJ23...?
Looks like Suzuki has cut off the supply line on some major parts to them...
I have a spare engine for mine, but no new bits for another rebuild :cry:
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
garry55
Post by garry55 »
thanks for that info - guess I will buy the same as you have (DC12-1) and hope for the best.
Sold both VJ23's a couple of years ago. They are OK, but a bit sterile compared to the VJ21. Just my opinion, of course. :up:
Garry
gammakeith
Country: United Kingdom
Suzuki 2-Strokes: 1966 T20
Post by gammakeith »
Yes, "modern" 2 strokes are a bit busy under the fairings but some engines just should not be covered up :P
I've got my RG500 partly stripped for some routine maintenance. I'm glad I did as one disc valve cover was starting to delaminate. Looking forward to doing some miles this coming year.
Keith
1948 Scott Flying Squirrel
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
Definately NO 4 strokes :-)
busa1300
Post by busa1300 »
The RG500 looks more user friendly to work on than my RZV500R.
I wish I had one of both to know for sure :mrgreen:
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
RZV 500 R
gammakeith
I have some friends who have worked on both and they would certainly confirm the RG is much easier to work on. After all, it is very closely based on the race engines. They do need treating gently though and there are several pitfalls. For example, if you look at the pics you will see the oil lines. They are so easy to trap when putting the carbs back.
Keith
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
