I ordered a natural gas grill. I have a gas supply about 15 ft. away from the grills location. The grill is not here yet.
Is it safe to use PVC for the line? NG is low pressure - about 7 - 9 psi.
OT Natural gas grill
- Suzsmokeyallan
There is some new flexible PVC lines available for water and other fluids/gases. The one for water is blue and i believe the NG is either yellow or red in sheath colour, so buy accordingly.
These guys have some nice flexible hose for natural gas.
http://www.mcmaster.com/#natural-gas-hose/=819zrk
They list 5 psi as max working pressure, so if you regulate it accordingly and check your burner specs you'll probably be okay.
Here's some flexible yellow coated stainless:
http://www.grainger.com/Grainger/items/7A0R5?Pid=search
I think this is the yellow pipe that Allan mentioned, but I think that its meant to be buried:
http://www.charterplastics.com/natural_gas.html
I think that pipe would probably be the cheapest.
1954 Harley ST165 basket in the attic
1972 Suzuki GT750 project in the works
1981 Honda CB750-1000 driver
1982 Honda GL500 easy project
Went to a local supply house (Empire Plumbing) yesterday and they have all the NG lines I need in yellow flexible PVC with stainless NPT ends already installed. They came in 1, 2,, 3, 4 and 6 foot lengths. The 6 footer coupled with the 10 footer attached to the grill should make the required run. I didn't buy anything because the grill is still not here and I don't know what type of connector it has.
They were labeled 'Natural Gas appliance supply lines' 'Suitable for indoor or outdoor use'.
