Pinholes in exhaust downpipe -- best way to fix?
My set of vintage expansion chambers decided to develop a couple of small pin-holes in one of the downpipes this weekend, I thought a V1 flying bomb was going overhead :oops:
The two holes are both less than 2mm in diameter, and the metal immediately surrounding the holes is solid (it does not yield to a good poke with a screwdriver).
What do you guys think is the best fix -- braze up the holes, or just stick a couple of blobs of weld on?
The pipes are painted black to conceal rust-pitting, etc, so cosmetic appearance does not matter.
djfisher22
Post by djfisher22 »
I'd braze em up. Easy peasy. 8)
2000 ZRX (the green ones are fastest)
72 GT750 (almost done)
73 RV 125
72 RV 90 X 2
Now proudly displaying membership number 91 in the Ugly Fat Old Bastards Motorcycle Club.
http://www.ozebook.com/cpotw/documents/register.html
H2RICK
Country: CANADA
Post by H2RICK »
I'd braze 'em too.....but rather than brass, I'd use high temp silver braze rod. More durable and less prone to cracking and resists chemical attack far better than brass/bronze. The trick is to find someone who can gas-weld AND
understands light gauge metal welding....:cry:
My .02 worth....
GT550A Mint & Original
MBD Sufferer
thanks for the tips, guys.
As it happens, the metal around the pinholes was a bit too thin to take a proper repair, so the welder ground out the bad stuff (about a 2" x 1" hole), made up a neat little patch, welded it in, then did a nice job of smoothing the welds. A quick coat of fresh satin black and you don't notice it from 3 feet away. All for $25.
It's good to have easy access to skills like that.
