Anyone in their work of personal endeavors have a line on a 4.5" or 114mm ID oil seal? Needs to be as compact as possible and thin as far as width as possible. I've found some but they are about a half inch wide... Was looking for something 1/4" wide range... No pressure differential as the backside is vented to the atmosphere...
Thanks!
Also posted on KTW..
4.5" or 114mm ID Oil Seal - THIN...
- Country: USofA
- Suzuki 2-Strokes: GT250 x 2, GS1100E
- advant63
- Country: canada
would automotive rear main crank seals work tom?
m12 or50 k10 a100
s32-2 s32-2 t250r
gt250 t500r gt550a
twin cobras in baskets
s32-2 s32-2 t250r
gt250 t500r gt550a
- H2RICK
- Country: CANADA
Tom, I can't believe CR would not have a suitable single lip grease-type seal in those dimensions. I'll drag out my catalogue and have a look-see.....
OK.....for a 4.5" OD shaft, we have a CR45025 suitable for a 4.5" shaft with a seal width of 0.250", an OD of 5.506" that requires a fitting bore of 5.501". It has a single lip nitrile sealing element and is intended for low shaft speeds and is NOT to be used for oil retention. This is basically a grease retention/heavy dirt exclusion type of seal.
There is also its close brother that WILL handle high shaft speeds and IS intended for oil sealing. All other dimensions are the same except the width is 0.375". The part number of this one is 44959. This one has a spring-loaded single lip design and is of CR's "Wave-Seal" construction
that basically "pumps" the oil back towards the oil side due to the sine wave construction of the lip elastomer.
They also have two other designs in the narrow 0.250 width but these have an all-elastomer composition which may not be suitable for your purposes.
Helpful ?? Yes ?? No ??
GT550A Mint & Original
MBD Sufferer
MBD Sufferer
- Country: USofA
- H2RICK
- Country: CANADA
Great, Tom, glad I could help.
That 45064 item is basically a wider version of the 44959 but it has a dual lip with the outer lip more for dirt exclusion rather than fluid exclusion. The elastomer is what CR calls a Long-Life Fluoroelastomer....and they list 2 kinds
depending on seal design and application: FKM good to 600*F and PTFE good to 700*F. Now that's a fancy Teflon to be good up to 700*F !!!
The 44960 is basically a thicker version of the 44959 with the nitrile elastomer but it has the dual lip dirt excluding design like the 45064.
Good luck with your project.
MBD Sufferer
MBD Sufferer
