carb soaking
carb soaking
Can anyone tell me what is the best thing to soak some gt750 carbs in? I have a lot of crusty deposits on and in them that I have not been able to remove with carb cleaner. someone told me limeaway might work, but I wanted to check with you guys first
http://www.aircooledtech.com/tools-on-t ... a_blaster/tz375 wrote:Suzukidave had a link to a great cheap soda blaster which looked promising for carb cleaning.
- Suzsmokeyallan
Limeaway is good but you have to watch it carefully all the time its soaking. This will also destroy the finish on any plated parts like linkages so you cant let those items get soaked.
Try using a toothbrush on the parts where its stained or caked and wash the part frequently as you go about those areas.
