decided to check my radiator level. Took off the rad cap, put just a bit of water in it and thats when it happened. There is an oily substance in my coolant. Floated to the top when I put in a bit of water. So, how bad is my problem? What could it be? It sure looked and felt like oil. Now mind you, the bike had been sitting for 9 months after I got it and no telling how long it sat in Erics garage without being ridden or even started.
So, how do I drain and flush the system completely and refill then ride it to see if it is a continuing issue? How could tranny oil even get into the cooling system? It sure didnt look like injector oil but maybe it could be.
Any help appreciated!!!!!!!!!
_____________________________________________________________
Update:
went to bike store to get some of super special antifreeze for aluminum motors and it was $21.00 for 1/2 gallon
Said screw that, went to where I work on saturdays and got some there for free. This stuff is compatible for ALL applications, yes even aluminum motors. Got home and drained the system. oily stuff was in it so I dumped in some purple power degreaser and flushed about 5 gallons of water after that till all water had no oil or coloration from degreaser or soapy bubbles. Seemed to work great. Refilled with my new antifreeze and started bike up. let it idle and blipped the throttle till I reached correct temp on my gauge. shut her down and looked at the fluid and all was as clean as could be!!! I will check it periodically to see if more oily stuff gets into it.
thanks for all the help guys!!!
