This is how it was when I bought it, as you can see it was in pretty good shape, especially compaired to my other GT500 which I found leaning against a friends barn. The previous owner had dropped it and decided to sell. I still have to pop a dent in the tank, but I wanted to get a chance to just ride it for a while before I did anymore to it.
First thing I did was dump the sissy bar and the luggage rack, then replaced the stock bars with a slightly lower set. I also drilled lower holes in the seat mount tabs and shaved the top off to get rid of the humped apearance of the seat that came with it. I also gave the carbs a quick clean.
During my first long test run I blew a hole in the right piston. So I sourced a new one and rebuilt the top end. I totally rebuilt the carbs, replaced the petcock and the fuel lines, cleaned the tank, added gas line filters, replaced the rear brakes, fixed all the short in the wiring, replaced the blown rectifier and the half dead battery, scrubbed the chain, replaced the clutch cable, cleaned out the pipes... oh and did I mention cleaned the hunks of piston out of the crank case?
