dip stick
elbert
dip stick
Post by elbert »
On the old board someone described how they made a dip stick for the transmission from an old oil plug. I want to make one myself but what is the recomended way of fixing the dip stick to the plug so that it won't come loose?
The most efficient way is probably to drill a hole in the filler cap for the dipstick (steel or aluminum rod say 2.5 - 3.00 mm diameter.
push in the new dipstick and then cross dill with say a 1.0mm hole but not all teh way through. Push in a 1mm pin through the cap and through the rod and it should be 100% safe.
elbert
Post by elbert »
Crossdrilling sounds like a good idea, I was planning to use plastic since it would cause less damage if it loosens and gets into the transmission. But with crossdrilling I guess I should be safe anyway.
Gordon
"Which one is not like the others?"
Post by Gordon »
Deleted
elbert
Post by elbert »
Gordon,
That sounds like the super safe mode, and since I have a spare plug I think I'll go for that one. It won't take much extra room in my tool kit...
GT Tim
Post by GT Tim »
Now that's thinkin' with your dipstick, Jimmy... er Gordon!
http://www.youtube.com/watch?v=Mj5ms9PJDNY
Gordon
Post by Gordon »
Deleted
frappy
Suzuki 2-Strokes: T500M, T250-II, GT750J
Post by frappy »
I wonder if a cap with integral dipstick from another bike would work?
'75 - T500M
'72 - GT750J
'70 - T250-II
I made a dipstick from a plastic tie wrap, which was held by a cross-drilled pin. It worked.
frappy
Post by frappy »
Sure would be nice if Dofin could post a picture of it :?
'75 - T500M
'72 - GT750J
'70 - T250-II
