'74 T500 is sick...needs cure.
KEEF27
Post by KEEF27 »
The Problem:
The right exhaust is a lot weaker than the other. The oil lines are not drawing oil. The bike has diminished power. The right cylinder doesn't fire at low rpms, and not all the time at higher rpms.
What I've tried:
Compression test, Both cylinders are good.
Replaced oil pump unit, banjo bolts and plastic washers.
New condensers and points.
I am thinking about installing a power-dynamo to get rid of all the old stuff.
Does this sound like the right way to go, or is there another route I should take?[/img][/list][/list]
T500s will drop the right cylinder if the battery is weak. I'd try that first.
H2RICK
Country: CANADA
Post by H2RICK »
What the heck is a "power-dynamo" ?? Is this some new technical term that I missed last summer or something ??? :lol: :lol:
GT550A Mint & Original
MBD Sufferer
GT Tim
Post by GT Tim »
Perhaps he means an electronic ignition? :?:
