curious about new Mikuni carbs?
Seems like there is lots of interest in new Mikuni carbs on Yamaha RDs.
Enough that you can get carbs setup for the RDs at:
https://www.economycycle.com/shop/yamah ... tle-cable/
http://www.motocarb.com/conversion-kits.html
And there are YouTube videos about the conversion. Here is one: https://www.youtube.com/watch?v=C6DN_6QKPb0
(Came across this video by chance, which got me curious.)
Anyone using new Mikunis on a Suzuki T250/GT250/T350/T500 twin?
What did you have to do & how is that working out? And Jetting?
Re: curious about new Mikuni carbs?
T250/GT250 info
ImageCarbOptionsVM24-28 by jabcb, on Flickr
ro55o
Country: yu
Suzuki 2-Strokes: t500, kz400,bsa b175
Post by ro55o »
I have fitted vm32s to my 71 t500.
Jetting and slide etc is close to t500 carb settings,
just used a hex main jet (110) rather than round.
Also used later needle profile 5FP17 .
Pilot is 27.5,
P4 needle jets both sides.
2.5 slides.
Pod filters.
The main problem is that the left hand carb will hit the engine casing so doesnt fit.
I made 2 aluminium angled inlet manifold plates to give the clearance needed.
Runs great!
New Mikuni carbs installed on the GT250 cafe build. Used VM28-49 carbs & VM28-200 holders.
New linked choke parts are not available. I used the linked choke from T500 carbs.
The new carbs aren’t as tall as the stock carbs. The stock carb cables do not have enough adjustability to account for this.
Used longer carb cable adjusters that are about 10mm longer. (They were in my parts inventory so I don’t have parts #s.)
Pic of adjuster from the new carbs & the one I used.
Pic of the result. Needed to use additional washers on the mounting studs.
grumpy56
Suzuki 2-Strokes: 1970 T350 Restored; 1972 GT380 Build
Post by grumpy56 »
Nice work!!!
