V4 RGV500
sportston
Country: England, UK
Re: V4 RGV500
Post by sportston »
Cool!
garry55
Re: V4 RGV500
Post by garry55 »
Thanks ! :up:
Garry
garry55
Re: V4 RGV500
Post by garry55 »
taking a break from the 4 strokes, I found time to finally persuade the Ducati 999 steering stem and yokes that they did want to fit in the SRAD steering head..........
then modified the steering lock stops on the Ducati bottom yoke.............
and cobbled together a steering stem nut spanner.............
and that's it until the modified swing arm is returned from the machine shop.
Garry
garry55
Re: V4 RGV500
Post by garry55 »
The swing arm is back from the machine shop, suitably modified so as to fit the SRAD frame.
Next job was to remove the SRAD's top suspension mounting bracket and make a pocket for the ride height control arm to run in, like so...........
Garry
garry55
Re: V4 RGV500
Post by garry55 »
then I cut a template for the new suspension upper mounting brackets...........
this was sent away for 2 replicas to be water-jet cut from 10mm aluminium sheet.
and whilst I awaited their return, I made a pair of bearing support brackets..........
Garry
garry55
Re: V4 RGV500
Post by garry55 »
water-jet cut brackets arrived...........
and with the bearing supports bolted in place...........
Garry
garry55
Re: V4 RGV500
Post by garry55 »
the brackets, with the bearing supports welded in place and bearings and inner sleeves fitted............
and with the Ducati suspension rocker arm in place...........
Garry
garry55
Re: V4 RGV500
Post by garry55 »
swing arm, ride height adjuster rod and rear shock installed..........
Garry
garry55
Re: V4 RGV500
Post by garry55 »
Rolling..........
Garry
garry55
Re: V4 RGV500
Post by garry55 »
tank and race tail in place...........
Garry
