He said if was "BDI", not "DBI" jab. And anyway, I've already solved the mystery of what it means, so don't worry, I feel sure I've steered DD in the right direction. Its only a formality that, now armed with the information I have supplied, DD will be able to find out who made the wheel.jabcb wrote:DBI Dynamic Bike Innovation appears to be an aftermarket parts manufacturer in Japan.
https://www.amazon.com/DBI-Piston-Front ... B007KPRX9O
My guess is that its from a bike with a twin-piston caliper. What is the Disc OD in mm?
Aha! All the best women come from Thailand (Did I mention my wife is Thai?). Perhaps they make great wheels too! Some of the Thai motorcycles are quite good from what I have seen while over there. Perhaps it is from a Thai bike?dollydog wrote:there is a company in thailand called bdi that make alloy bits. i already knew that, just didn't fancy phoning them up to aska few more clues: the disc is 220mm o.d. the spindle size is 12mm. the tyre is a 3.00 x 17 and the markings on the rim say: J17 X 1.40 C 12 86 DOT. from that i'm guessing it was made december 1986? also on the rim is: FUTUBA JAPAN J1.40 X 17 - 1707 - 1.2.
hope this helps![]()
