Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sat Jul 20, 2019 7:27 pm
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: 6A battery ok for gt380?
PostPosted: Fri Jul 13, 2018 7:39 am
Offline
Country: Lebanon
Bikes owned: gsx 750R, GPZ 750, GT380
Hi
I've just doscovered that my battery can no longer hold a charge. The gt380 battery is a strange size and it's not easy to find here in Lebanon. But a local dealer has one, but it's only 6A. I'm guessing this will work, no? Plz let me know your views
thanks
MJ
Top
 Profile
PostPosted: Fri Jul 13, 2018 11:10 am
Offline
Same size battery the T500 uses. Easily obtainable here.....can even order from any auto supply.
Your dealer can't special order one?
Might try entering '12N7-4A' or 'YB7Y-A' into your search engine and see what pops up in your area. Aside from the actual battery manufacturer, Yuasa, there are a lot of different 'marketing' brands. Scorpion, Power Sonic....the list goes on.
If not, maybe try this route....
https://www.yuasaeurope.com/" > https://www.yuasa.it/stores/pages/view" > May not deal in small lead acid batteries but it might be worth a contact. If not, maybe they can give you contact information for a local distributor that does....maybe a different brand...Scorpion, etc. http://www.itgholding.com/affiliate/11/ ... solutions/"
Good Luck
_________________
_____________
______________________
Top
 Profile
PostPosted: Fri Jul 13, 2018 11:29 am
Offline
EDIT:
_________________
_____________
Top
 Profile
PostPosted: Fri Jul 13, 2018 1:09 pm
Offline
Country: England, UK
If it physically fits ok, using a higher amp battery than standard should cause you no discernible problems and may in fact be an improvement.
Top
 Profile
PostPosted: Fri Jul 13, 2018 1:31 pm
Offline
Country: Lebanon
Actually it's lower. the original one was 9AH and the one i found is 6AH. I can't imagine it being a problem, as the pull from the battery isn't that much on these bikes, but i wanted to see what the panel thinks...
Top
 Profile
PostPosted: Sat Jul 14, 2018 8:36 am
Offline
I wouldn't recommend running smaller than the recommended 7Ah battery. It may cause eventual charging problems. Though it would work sufficiently to run the bike, you might find the battery would go flat more easily and the charging system would be put under more pressure, especially while you were running with headlights and other electrical loads.
Top
 Profile
PostPosted: Sat Jul 14, 2018 10:41 pm
Offline
Country: Lebanon
thanks. Good point. Yesterday i managed to find the original 9.5AH battery for a snip at only 23 bucks.
Top
 Profile
PostPosted: Sun Jul 15, 2018 10:41 am
Offline
Excellent. Glad to hear you got that sourced ok
Top
 Profile
PostPosted: Wed Nov 07, 2018 7:05 am
Offline
I run a 4 AH battery in my GT750. I don't use the electric starter, so no problems.
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 4 guests
Search for:
Jump to:
cron
Suzuki2Strokes.com
