not much to report really, but barrels are at sep in kegworth, hopefully being worked on as we speak. unfortunately, as it's this time of year they need to do priority jobs first, such as race bikes and believe it or not, tractor parts
all powdercoating should be done by the middle of this week, so i can at least start putting the rolling chassis together on the bench. when i get the barrels back, i can send them off to a nice kind person who is going to mill the mouths out and match the transfer ports to gt250a size, both on the barrels and the crankcases. crank itself was a newly rebuilt unit, but had conrods with 14mm gudge pins, so i've had to do a conrod swap as the ts185 pistons are 16mm gudge. not too pricey at £60 including vat
barrel work is just a tad more
so, no photo's yet. will post as and when.
ps, just to add. cylinder heads will be milled out to 64mm and we're going to copy the squish pattern/dimensions from a ts185 head. got to start somewhere
obviously the depth of the dome will be different, as the ts head is very deep.
