Hello
I removed a plate from the end of the oil pump which is held on by 3 posi drive screws but it will not fit back flush there is a small tongue on the inside of the plate and I do not want to force it.
Has anyone had one apart before.
Paul.
OIL Pump T250
- Country: United Kingdom
- Suzuki 2-Strokes: T250 Hustler
- Country: england
Re: OIL Pump T250
easy
presume you have the oilpump off? anyway hold pump in left hand. triangular plate can only go on one way and that's the tab to the inside right [as you're looking at it]. press the plate on with left thumb and at the same time press the control arm [the one with the spring on it] back and forth with right thumb until the plate drops on flush. put screws back in and good to go. don't forget the 'o' ring though
- Country: england
Re: OIL Pump T250
that's quite ok mate - anytime, just ask
Re: OIL Pump T250
Hello DD
Took your advice and tried it tonight and it worked fine screws fitted and back to together just ordered a gasket then I will fit it
Thanks Paul
Thanks Paul
