Does anybody have the T500 part no. for..
tricky1962
Country: United Kingdom
Suzuki 2-Strokes: T500J
Post by tricky1962 »
The grommet that protects the blue neutral switch wire between the sprocket cover and the alternator cover?
Sorry for the inane question, but I can't see it anywhere and as I'm shopping for parts would like to include it.
It must be a simple half circle grommet but..
Jimroid
Re: Does anybody have the T500 part no. for..
Post by Jimroid »
31485-15020
tricky1962
Cheers, but correct me if I'm wrong. I think that is the grommet at 12 'o' clock for the wires from the generator.
I need the grommet at 3 'o' clock which solely feeds the blue wire from the neutral switch
Jimroid
Post by Jimroid »
I'd have to pop the cover off to look,so not sure at this point.
tricky1962
The notch in the casing is just about visible here
http://www.ozebook.com/compendium/T500parts/image7.htm" onclick="window.open(this.href);return false;
but I am now thinking it is too small for a grommet. Maybe the insulation on the wire should be thicker at that point to protect the conductor?
