T500 Steering Lock removal?
Mgmark
Suzuki 2-Strokes: ‘75 GT750, '19 Triumph T100
Post by Mgmark »
The ignition switch has been replaced on my '74 T500 resto project. Is it possible to remove the lock cylinder and re-key to match the ignition? Or I can probably rekey the new ignition to the lock if I order a new pre-cut key.
Mark
Re: T500 Steering Lock removal?
A competent locksmith will make a key that works in both.
Mgmark
Post by Mgmark »
titan performance wrote:A competent locksmith will make a key that works in both.
I'm just wondering if I can be that competent locksmith. Does the steering lock come apart? If not I will order an oem precut key for the steering and then rekey the ignition switch to match that. I know from past experience they arent too hard to do.
Not something I have attempted myself.......but I guess you could. They must both come apart.
Mgmark
Post by Mgmark »
I received the new oem key to fit my steering lock, which works fine. I then disassembled the ignition switch and changed the tumblers to match my steering lock key. I found it to be as easy as Yamaha re-keying. So now one key fits the entire bike. Result!
Mgmark wrote:The ignition switch has been replaced on my '74 T500 resto project. Is it possible to remove the lock cylinder and re-key to match the ignition? Or I can probably rekey the new ignition to the lock if I order a new pre-cut key.
Both options are possible - I show the how the lock comes apart at this link, and the ignition at this link. Making the ignition match the lock is perhaps a bit easier, but neither option is difficult. Good luck ! 8)
