what is capacity of T500 Oil tank?
- Suzuki 2-Strokes: T500, S32-2, GT185
Not the crankcase oil capacity but the 2 cycle oil tank. I am looking to have a 4" diameter cylindrical oil tank made that's about 8" long. Total volume of that cylinder is around 1.7 quarts. I am just wondering how quickly I would burn through 1.7 quarts and how that related to the stock oil tank volume.
Re: what is capacity of T500 Oil tank?
I don't have a T500 but I'd say you are right in the ball park. Maybe a tad more than the stock tank held. Are you going to incorporate a sight glass?
Be sure you mount the tank with its outlet above the oil pump inlet. These pumps don't have the ability to suck oil - only push it. They are gravity fed.
Did some more searching and the stock t500 holds 1800cc, which is about 1.9 quarts. Looks like my new tank would be a tad smaller. Guess I'll have to fill it more often. It will be higher than pump, so gravity feed should work. No sight glass planned although that's not a bad idea.
- Country: Australia
- Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
You should at least get 1000 kilometers (600 miles) from that.
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
1973 T500
2012 Ninja 650
I knew you were close. A GT550 (feeding a third cylinder) holds 3.2 pints - just over 1500cc
WRONG! I knew better that to look at the Clymer figures. ACTUAL is 2.5 pints -- 1190cc for the GT550 So I'll be adding oil way before you do
