Okkkkkk...so I finally got back to the rebuild this week and here is my report back.
1. The bike sounds ok when started and sometimes it seems like either the right or left cylinders don't fire. I'll feel for back pressure from the exhaust and reach upfront and touch the exhaust and it will be lukewarm at best. The other day it was the right cylinder, tonight it was the left cylinder. Checked for spark and it was there. The biggest problem with this bike is that it turns over no problem but as it heats up and stays on for about 7 minutes, the rpm's come down and it starts to bog down and sound flooded or starving like it did previously. I changed the piston rings, and found out that the shipper sent the wrong rings and now I'm up to 130psi in each cylinder. This is with the carbs off and exhaust buttoned up.
2. The battery seems to be draining so I want to get everyone's advice for testing the charging system (alternator, rectifier, regulator, etc.). At this point with all the money if spent, is it worth just changing out the system and going with electric spark? Or if anyone has a recommended solution I would love to hear it. At this point I'm just hoping to get this thing out for a few rides before the winter hits! haha. When I was running the bike the other night, the battery stayed static at 11.38 volts with the bike running and no increases when revved. Tonight, I charged the battery over night and was around 12.58 and started to slowly drain and the same happened with the bike running, volts were around 12.18 and no increase when the bike was revved.
I also noticed a lot of smoke the other night coming out of the left cylinder, (the cold one) after the bike cut out. Trying to research more into this but I think its just the oil heating up and not burning properly. The carbs from my perspective have been thoroughly cleaned, inspected 3 times over, new floats, new jets, everything buttoned up properly. I have attached short video of what is happening when the bike heats up and shuts off.
https://www.flickr.com/photos/131622719 ... res/112435" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
And a picture of the plugs from the other night when I was having issues with the right cylinder not firing.
Once again, appreciate all the help!
