On the left is one of the four bulbs that came installed on the cheapo Taiwanese turn signals I bought. 6 volt, 8 watt. I wonder why the didn't blink On the right is what it takes to make the flasher unit work 12 volt, 23 watt. Luckily, there was enough room for the larger bulb.
Coyote wrote:On the left is one of the four bulbs that came installed on the cheapo Taiwanese turn signals I bought. 6 volt, 8 watt. I wonder why they didn't blink On the right is what it takes to make the flasher unit work 12 volt, 23 watt. Luckily, there was enough room for the larger bulb.
I had the same issue with the eBay turn signals I bought off eBay. Same solution, too. But i even swapped in the original lenses as well. I like the red lenses on the back better.
