Moderators: oldjapanesebikes , H2RICK , diamondj , Suzsmokeyallan
Posts: 3404 Joined: Tue Oct 21, 2008 2:41 pm
Post
by Coyote » Wed Mar 11, 2015 3:35 pm
1) which way to the 'teeth' on the clamp face when mounted?
2) which end of the rubber goes against the teeth? I think the thick side but not sure.
3) the crossover pockets on the junctions still have some of the OEM glop in them. it's impossible to dig it all out. Is there something that dissolves it, or just put it together and not worry about it?
Vintageman
Posts: 1485 Joined: Tue May 18, 2010 5:38 pm
Post
by Vintageman » Wed Mar 11, 2015 4:37 pm
answers some of your questions
http://www.ebay.com/itm/1975-Suzuki-GT5 ... 520wt_1222 " onclick="window.open(this.href);return false;
http://www.ebay.com/itm/Suzuki-GT550-GT ... 281wt_1222 " onclick="window.open(this.href);return false;
73 Kawasaki H1 500
Posts: 841 Joined: Tue Feb 19, 2013 2:45 am
Post
by GT750Battleship » Wed Mar 11, 2015 4:54 pm
+1 with Vintageman...let the pictures do the talking
Spamy
Posts: 37 Joined: Wed May 08, 2013 8:41 am
Suzuki 2-Strokes: Several
Post
by Spamy » Wed Mar 11, 2015 6:32 pm
On mine, the thicker side to the teeth to keep the pressure from pushing the rubber peice out. Then the step in the inner rubber at the joint, smaller id to outer pipe, larger id to smaller pipe.
Post
by Coyote » Wed Mar 11, 2015 7:43 pm
Thanks Men! Do you guys get all the old snail snot out of the crossovers? Some of it is really stuck! And sticky / rubbery.
Cliff
Posts: 476 Joined: Sun Dec 14, 2008 9:34 am
Post
by Cliff » Wed Mar 11, 2015 9:21 pm
Teeth to the header, thick rubber to the teeth.Thick rubber to the header, thin to the muffler.
Try soaking the crossovers in drain cleaner (Drano or Liquid Plumber for example). 10 to 15 minutes should be enough. It's caustic (sodium hydroxide) just like what's in a hot tank at the rad shops!
Post
by Coyote » Thu Mar 12, 2015 3:24 pm
So is this the correct way? Just shove these on till the rear mount lines up?
Posts: 6213 Joined: Mon Nov 03, 2008 10:47 am
Post
by tz375 » Thu Mar 12, 2015 3:36 pm
Correct.
You can always smear some High Temp gasket goo around the pipe as a lubricant and wipe off any excess once the pipes are mounted.
Post
by GT750Battleship » Thu Mar 12, 2015 4:10 pm
Hi,just leave header pipe slightly loose so it can swivel & align things correctly
then tightnen everything up.
