GT185 Crankshaft Seals
sandsz
Suzuki 2-Strokes: 1976 GT185
Re: GT185 Crankshaft Seals
Post by sandsz »
tz375 wrote:If you don't mind me asking, what sort of jigs did you need to build to press the crank apart and what press did you get
A Harbor Fright 20-Ton press, some 2x4 wood, a spare socket about the size of the conrods and a Harbor Fright bearing puller. Nothing special, it was actually easier to pull the crank apart then to drill out and extract two of the counter-balance weight screws that stripped on me. You have to remove the weight because it obstructs half the conrod to press on. I just put the bearing puller on under each part, chocked it up on some 2x4 wood laid down on the press blocks (that come with the press) and put a socket on the conrod then pressed down. I don't think a 12 ton press would get the job done but who knows. I got everything on sale plus 20% discount and it came to about $200 for the stuff below.
Press : http://www.harborfreight.com/20-ton-sho ... 32879.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Bearing Puller Kit : http://www.harborfreight.com/bearing-se ... 93980.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
First thing I did was buy some longer grade-8 bolts and nuts for the puller because it wasn't quite big enough for car bearings, which cost me like $4 at Tractor Supply.
I pulled from the kick-starter side but it would have been easier to pull from the generator side, two less bearings to pull and you wouldn't have to unscrew the weight. I pulled them anyways to clean them up in the good old ultra-sonic cleaner and recondition them back to as new as I can. They all spin freely but it can't hurt.
Alan H wrote:Don't run CCI engines on premix. The cranks are designed to move oil AWAY from the bearings & seals. Perhaps the oil pump wasn't working too good in the first place which caused the seal problem originally.
make sure everything is well lubed - seals & bearing wise when you rebuild,- but check the pump and prime the pipes before you start it!.
Thanks Alan H, the guy I bought it from said a "shop" built this bike as a cafe racer and it ran fine for a while then stopped. I knew the guy was a bit shady when he said the button on the side cover was a "kill button". What it turned out to be was a button someone wired in to a relay to spin the starter/generator. Well it would "kill" the motor because one starer brush was BROKE and the wire was BURNT. I replaced both and, Voila, it now works great. I'm sure after the crank seals were fried someone kept cranking the bike and eventually burnt the brush out.
I'm thinking old seals + CCI delete running "premix" culminated in to failed seals. To be 100% honest, I didn't know what a CCI was before starting on this project but I got the manual and followed the trouble-shooting flow chart. Top end compression was great, the cylinder jug seals were good but there was no intake pressure sucking air in. I just taped paper in front of the intake holes and they didnt even try to "suck in" when starting. No sucky, no fuel.
It was a scary thought about "pulling the crank" and pressing it apart but as of right now I'm pretty confident I could pull the motor, the crank and pull it apart in an evening. I love how the manual tells you not only how to do it, but what tools you need, socket sizes and even torque specs when you put it back together. How convenient!
sandsz
Post by sandsz »
Well... in for a penny, in for a pound.
So I read up on how to true a crank because, well, I didn't want to have done all this work just to put a wonky crank back in. I found the basic equipment I need to do this correctly and now I have another shopping list.
Two machinist magnetic stands, metal arms. 3lbs base, 7" rise, 5" extension
Two dial indicator kits with end kit. 0.001"
Two precision ground "vblocks" 5" X 2" X 3-1/8", V cut 2-1/2" 90 Degree
One digital Caliper 6", 0.001"
One brass hammer 16oz
A bucket of Patience beer
I found all these parts and am waiting on them to come in so I can true this crank up... correctly!
Yeesh grab a cyl. hone and I might as well start collecting old small bikes in general and start restoring them. :/
Starg with the beer and thinking time.
These are the most important parts.
sandsz
Post by sandsz »
YAY, yesterday I got the dial gauges, magnetic stands, caliper, brass hammer and v-blocks! And the beer!
Now all I need is time to play with the crank. Who knows I may actually be able to true the crank soon.
Then I have to remember how to put the motor back together, :roll: :roll:
sandsz
Post by sandsz »
Found time to take everything out and calibrate. From what I've seen before this looks like a standard setup. Next step level the table, press the crank together as close to true as possible then have at it.
