Jemco Swarbrick chambers?
- Suzuki 2-Strokes: 75' T500, KTM Superduke
Re: Jemco Swarbrick chambers?
I have no idea, but thinking about it, Dave Sawrbrick sells his chambers partially assembled and my guess is that an owner put the together like that for whatever reason and those pipes were then replicated by Jemco
- Suzuki 2-Strokes: '69 Rebel, '75 Indy
For what its worth - my 1992 ZX-11 came from the factory that way and from what I've seen they all did.
1975 GT550
- desmocat
- Suzuki 2-Strokes: T500, TS250, B105P, GS250T
My chambers on my race bike are the same.
I'm not sure why, might have to do with having one side higher so axle can be removed? Doesn't really make sense because it on the wrong side.
Ralph Spencer
Spencer Motoworks LLC
Southfield, MI USA
www.spencermotoworks.com
AHRMA #798
Southfield, MI USA
AHRMA #798
It's really getting to my ocd side, I think I'm going to let it slide as I need to modify the pre-chamber section to fit inside the fairing as it is.
I would sleep better at night if they were symmetric, but at that point I might as well make them from scratch.
That would drive me nuts too. I wonder if anyone hs a good picture of Swarbricks assembled by Dave Swarbrick to see if they are different.
Strange.....looks dreadful. I can think of no logical reason for that.
I wonder if they could be for flat track racing? More ground clearance on the left side - but then why not raise the right too... or bring both pipes out on the right - just a wag
1975 GT550
Just my 2 cents worth but I'm looking to get chambers for my T500 and if they came like that they'd go right back. I may have to reconsider Jemco.
Worrying is simply praying for something you don't want.
- Country: Wales
- Suzuki 2-Strokes: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Have you got a full pic of these pipes from the side.
There a topic with pics on CafeRacer.net
Shows Swarbick pipes that have symmetrical high mufflers. Also shows same bike with different pipes + mufflers below the axle.
http://www.caferacer.net/forum/project- ... ild-6.html
Ya, I was pretty bummed when I got them up on the bike. They look beautiful but the fitment is horrible, the down pipes coming out of the head are cockeyed and bang into each other. They honestly don't even come close to fitting well. I'm at the point of paying someone to totally rework the front and rear section. Hey look at my $1000 exhaust!!
- Country: Wales
It's very difficult to tell from the pics,It looks like there is a angle cut on the last cone on the left side,
But looks like the same cone on the right side has straight cut.
Would i be right in saying this,Or is there a angle cut and the cone turned outward,
In which case the end of the pipe would sit lower and away from the frame, creating a bigger gap between The muffler and swingarm.
Just to be clear here, we are talking about Jemco replicas of a set of Swarbrick pipes - not original Swarbrick pipes from Dave Swarbrick in the UK http://www.swarbrick-racing.co.uk/early.php" onclick="window.open(this.href);return false; and not the normal JEMCo pipes, right?
Yes you are correct. The last cones are cut slightly different, and the pipe to the silencers are bent different. Not a hard fix, but I wanted to keep the nice looking raw finish.old racer wrote:It's very difficult to tell from the pics,It looks like there is a angle cut on the last cone on the left side,
