I removed the water pump (luckily it came out pretty easily) and found that both O-Rings (pictured) were tore up pretty bad, so I replaced them. Oil was slowly dripping out of the weep hole after short rides so, after reading up on this board, assumed this was the cause.
I ordered the 2 o-rings from bike bandit utilizing the stock part numbers, lubed them, slid the water pump back up in until I found the notch and gently tapped it back in. Circlipped it and everything looked great!
I rode the bike around for about half an hour to get the motor hot and no drips.... success! Until the other night, spent about an hour on the bike, parked it still no leaks. Woke up the next morning and a puddle of oil under the bike the size of a dollar bill, and dripping from the weep hole again.
Did I do something wrong here? I didn't disassemble the water pump (largely because I couldn't figure out how) but I did order #10 as well, and still have it. Maybe an O-Ring failed or got pinched when I slid it back up in there? Guess I'll be pulling it apart again.....
