Suzukidave wrote:I also see a piece of the center piston missing and what looks like a seizure on the end piston , lower end of the rod looks real dry maybe you lost oil supply and it took everything with it ?
You're exactly right Dave, I think what happened was the lower bearing started to go dry first, then went bad causing unwanted piston movement, the lower skirt of the center piston eventually made contact with the crank case or a port and sent pieces of itself all over. (I was on the freeway ~70mph when I heard/felt the piston explode and pulled over)
What I've left out so far (because it shames me to think I may have caused this
), is that the day before this happened I noticed for the first time
EVER, not only was my oil tank dry, but so were my feeder tubes except for a small amount near the valves
. This baffled my mind because no less than the week prior i had just topped off the tank with fresh oil, I've always been anal about making sure I have more than enough oil before I go ride, BUT what I also noticed when I realized I had no oil, was that the oil tank cap was missing from the tank and was actually next to the battery... This means I either forgot to put the cap back on after the fill up or it rattled loose. So my next thought was that perhaps a fair bit spilled out the top while riding, but yet I had no signs of oil leaking anywhere (checked back of rear fender, oil tank itself, swingarm pivot, the ground, no oil anywhere...) This led me to think what if the cap provided some kind of a minor vacuum for regulating the pump? If so and the cap was missing then the motor could have been sucking down oil faster than normal since I topped off...??? To add to the chaos, my truck refused to start that morning. So I primed the lines with fresh oil on the GT and filled the tank to the brim again and rode to work that morning taking special care to baby the motor and pay close attention. Everything seemed solid (I've been commuting to work on the 550 2-3 days a week 45 miles each way for months), didn't hear any funky sounds or changes in power so I thought I got real lucky and it hadn't actually starved anything from oil. Also rode around during my lunch break and same thing no issues same power, reliable bike. Day ended, I rode back home about 43 miles, was about 2 miles from my house just about to exit the freeway when the piston blew
So the mystery question for me is if it's possible that the cap being loose or off the tank could have led to an increase in oil consumption?
Be gentle, I'm still grieving a serious loss...
