Here i go again ..
Here i go again ..
Another try to finish this dang thing Image Image
Re: Here i go again ..
Y E S :up:
Now take your time to work out where you are at and let's talk. If you forgot my phone number, email me and let's walk through this and get it up and running.
I think maybe we need more radical porting though. That chassis can handle a lot more than we planned on feeding it. :roll: :wink: :shock: :lol: :lol:
water cooled
Post by water cooled »
Excellent Dave! Your EFI bike is of great interest! Very glad to see you pull it back out! :D
Thanx Guys .. its going to be fun figuring this out with out my wiring n tuning guy handy ( my son )
How far did the wiring get last time and did you start off by matching basic lights etc to the chassis wiring or did you start with sensors to connect to the ECU?
Thinking about it, maybe teh easy way to sneak up on this would be to get the chassis electrics sorted first and then connect the ignition and then the charging system and then sneak up on all the new/additional wiring.
Even though it it sure doesnt look it a lot has been done , all the front and lights , turn signals and brake lights . Its still a lot of the ECU that needs the hooking up .
That's good. Next should probably be the ignition system and charging because they are quite simple.
Then work down a list of sensors and connect them up one at a time. Then power up the ECU and see what all the sensors are reading. Typically they get their 5v feed from the ECU and they may need to have their own ground leads back to the ECU.
Good to see this back on the bench Dave - looking forward to seeing how it progresses ! :up:
busa1300
Suzuki 2-Strokes: RGV RGV RGV RGV ......
Post by busa1300 »
Seeing that move under it's own power, will be serious motivation for a lot of us here, to attempt the seemingly impossible ourselves.
Thanks for the inspiration and ideas :up:
How's that 86 GSXR going?....mines still waiting for attention. :(
MY TWO STROKE ADDICTION
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
GT 750 J....sold.....
SX-R 800
KD 80
JR 50
RZV 500 R
https://www.youtube.com/@wedgehorsepower9869/videos
I have been toying with this project for so long i know many would like to see it done just so i stop talking about it :roll: but i too would love to see it run . The Slabbie had to have the engine replaced after i first got the project as the one that came in the boxes was oil starved and siezed up .. now after getting to run it hard i have discovered a oil leak from the left front of the cam cover . Turns out the cover hold down screw is completely stripped out ( just pulls right out ) so its going to need a heli coil put in so while i am in there might as well replace the cover seals and adjust the valves . I like these old bikes have the screw valve adjustment . I was very surprised the power and sound between the GSXR and the 1200 Bandit with a similar looking engine to be so different . :shock:
garry55
Post by garry55 »
Looks interesting - is there a previous post explaining what it is / where it was at?
I'm guessing from the banter that you are attempting to fit fuel injection - using carb bodies?
I'm intrigued........... :D
Garry
There was a whole buildup thread on this project years ago but got deleted in the switch to the new forum but its a reeded , converted to GS750 transmission and hopeing to be FI with a microsquirt ECM and Yamaha R1 FI throttle bodies . In a 99 GSXR750 frame .
garry55
Post by garry55 »
WOW !! that looks really trick Dave.
I read a lengthy article about a guy in the USA who converted his 350 Yam to run EFI using Micro/Megasquirt equipment - very interesting it was too. Of course, I can't find it now.........
Garry
garry55 wrote:WOW !! that looks really trick Dave.
Yep .. he was my inspiration http://www.smcomp.com/~smurph/RZ-EFI/index.html" onclick="window.open(this.href);return false;
