T500 Spark Plugs
- Suzuki 2-Strokes: T500 GT550 RM125 RM250 TS250 RM400 CR250,
T500 Spark Plugs
I found some NOS B77-HC plugs (OEM T500 plug) and know they've been discontinued for some time. I think the replacement plug is the B7HS. So my question is what's the difference between the two plugs? Thanks
Re: T500 Spark Plugs
I am not sure what the difference is.
You can still get B-77HC on eBay
I have run the B7HS. Now running the Iridium version of them BPR7HIX with caps without resistor
Denso makes some too and others
This is interesting http://www.ozebook.com/compendium/t500_ ... pspecs.htm" onclick="window.open(this.href);return false;
And NGK calls out B7hs
73 Kawasaki H1 500
73 Kawasaki H1 500
- Country: United Kingdom
- Suzuki 2-Strokes: T500J
Full info on the NGK codes is here
http://www.ngksparkplugs.com/techinfo/s ... berkey.pdf" onclick="window.open(this.href);return false;
But as I understand it, the 77 was a bit cooler than the 7, but not as cool as the 8. The difference was small though (as I understand it)
I'm currently running 7s but have used 6s in the past with no problem (but no high speed highway stuff either, all small roads)
NGK says they were discontinued in 1983 and couldn't tell me the difference as their books don't go back that far.
