You know, I had been giving this some thought and wondered if it would cause the centre head to run hotter if it was cut from the other two. Wouldn't it stop a certain amount of heat from being conducted away?Pete O'Dell wrote:its std practice to cut the heads in half and separate them for any tuning
I'm in two minds whether to separate mine or not. On the one hand it is less likely to blow a head gasket and need regular retorquing as much but I am wary of getting that centre too hot. I've heard they seize in the middle more often the outer two. I'd hate to make it any worse. I can't help wondering why Suzuki made the head in one piece?
Have you had a lot of personal experience in owning and running GT380s with the heads cut Pete? Did you ever find they seized under hard use?
I do plan on riding mine hard. I always do, so I want to engineer in a reasonable factor of robustness as well as speed. I suppose it is that, ever difficult to achieve, balance between power and reliability.
