Seat Cover Installation
- Flywheel
- Suzuki 2-Strokes: 1974 GT185
I bought one of those reproduction seat covers off of eBay. Any tips or tricks I should know about before I start? Should I let the new cover sit out in the hot sun to make it more plyable?- stuff like that. I've done dirt bike ones before but athestics dont apply there. Thanks in advance.
- Country: Australia
Re: Seat Cover Installation
- kettle kid
- Suzuki 2-Strokes: GT380A GT750L GT750J Z900
Get everything warm, use a hair dryer, use it to get all the creases out once fitted, get the glue tacky on foam/cover before applying the cover... Good luck..
- oldjapanesebikes
It actually would help to have an idea which one you bought. Some suppliers do not supply the new cover with a finished edge, but expect you to do this. For these I find it best to take the whole thing to a pro as they have the right sewing equipment to stitch in the edge bead. Others supply the cover with the edge finished and with a bead sewn in so you have something to clamp to and are easier to do yourself.Flywheel wrote:I bought one of those reproduction seat covers off of eBay. Any tips or tricks I should know about before I start?
Which type do you have ?
- Flywheel
I got the one that has the edge finished.oldjapanesebikes wrote:It actually would help to have an idea which one you bought. Some suppliers do not supply the new cover with a finished edge, but expect you to do this. For these I find it best to take the whole thing to a pro as they have the right sewing equipment to stitch in the edge bead. Others supply the cover with the edge finished and with a bead sewn in so you have something to clamp to and are easier to do yourself.Flywheel wrote:I bought one of those reproduction seat covers off of eBay. Any tips or tricks I should know about before I start?
- RING_DING
- Suzuki 2-Strokes: 1974 GT750 B-4 (JDM), 1975 GT750M
- Flywheel
RING_DING wrote:From Pit Replicas?
No, Hondasvintage.
- oldjapanesebikes
OK - that definitely makes it easier ! All I'd add to what 'kettle kid' offered earlier is to make sure your tabs are in good shape on the seat pan, and have a number of good spring clamps handy to temporarily hold the cover on the pan while you work out the creases and stretch it over the tabs. If the plastic edging on the seat pan is shot, you can use duct tape - you need something, otherwise the edge of the metal pan will eventually cut through the fabric. As 'kettle kid' mentioned, the most important thing is to have everything nice an warm before you start.Flywheel wrote: I got the one that has the edge finished.
Good luck !
- Flywheel
Thanks guys!
