Cleaning out T500 petrol tank and oil tank
- Country: New Zealand
- Suzuki 2-Strokes: 72 T500J, 72 Kaw H1-B, 71 CB750 K1, 67 A7SS
I have had my T500 petrol tank and oil tank repainted and I would like to remove any paint dust etc from inside the two tanks before I use them. I can blow compressed air through the fuel valve hole so that any dust is blown out of the petrol tank via the fuel cap inlet on top of the tank, however what can you use to flush out the oil tank?
Re: Cleaning out T500 petrol tank and oil tank
Mmmm ... pictures please. Love looking at newly painted tinware. Who did you get to do it? Hows about bringing the oil tank down to the Pubnite so I can see it in the flesh?
72 GT750J
71 TS250R
71 H1A
72 GT750J
71 TS250R
71 H1A
- oldjapanesebikes
I gave both a good interior rinse in my parts washer (obviously with the fuelcock and other fittings removed) , and checked the inside with a maglite till I was happy they were clean. Seemed to do the trick.Syd wrote:I have had my T500 petrol tank and oil tank repainted and I would like to remove any paint dust etc from inside the two tanks before I use them. I can blow compressed air through the fuel valve hole so that any dust is blown out of the petrol tank via the fuel cap inlet on top of the tank, however what can you use to flush out the oil tank?
The trouble is, the oil tank and petrol tank have already been painted so not that keen about letting anything touch the new paint. Just wondered about what product I could use apart from petrol to part fill the tanks and then give them a good shake around and then drain them out to dry?
- oldjapanesebikes
I'm using a light distillate petroleum liquid in my parts washer - trade names are things like varsol, mineral spirits, paint thinner, etc. Its pretty gentle on quality, clear coated paint and the idea is to get most of it on the inside of the tank, not the outside so I used the washer pump and flex arm directed into the tank - it wasn't immersed.Syd wrote:The trouble is, the oil tank and petrol tank have already been painted so not that keen about letting anything touch the new paint. Just wondered about what product I could use apart from petrol to part fill the tanks and then give them a good shake around and then drain them out to dry?
If you are really concerned, then I'd suggest some detergent and water, give it a good swill, rinse and then spray with WD40 or some other spray oil to stop the flash rust. I'd still use the maglite and mirror to get a good look whether it is clean or no.
Good info - thanks
- mike1161
- Suzuki 2-Strokes: 1970 T350, 2012 Triumph Thruxton
Agreed, all good ideas & info. But the approach I use is to do all the interior cleanup (de-scale, remove rust, coat with POR-15 Tank coating kit or your choice) first, then after the coating is all cured, I plug the holes with rubber stoppers (can get many sizes from any lab supply place), then nothing gets in at all while I do all the sanding, prep, and painting. Nothing to worry about after the paint is done, just mount & fill with fuel
Always has worked like a charm for me.
Current bikes: 1970 Suzuki T350, 2012 Thruxton
Previous bikes: '71 Honda CL350, '82 Yamaha 550 Seca, '86 Yamaha RD350, '88 Suzuki RG500 Gamma, '86 Suzuki VS700, '75 Kawasaki Mach II (S3), '12 Triumph Bonneville T100, '08 Triumph Daytona 675 SE
That's the proper order of things alright. But to answer the original flush question, I would use plain old rubbing (isopropyl) alcohol. Won't attack the paint at all. I use it all the time to clean painted surfaces. Dump a quart in to the fuel tank and shake to your hearts content. Use about a pint in the oil tank and repeat shaking. Air dry for a couple of days. In reality, any residual alcohol left behind will blend with the fluids and won't harm a thing.Agreed, all good ideas & info. But the approach I use is to do all the interior cleanup (de-scale, remove rust, coat with POR-15 Tank coating kit or your choice) first, then after the coating is all cured, I plug the holes with rubber stoppers (can get many sizes from any lab supply place), then nothing gets in at all while I do all the sanding, prep, and painting. Nothing to worry about after the paint is done, just mount & fill with fuelAlways has worked like a charm for me.
