RB got the record because the class was never run before.......
He could have pushed the bike down the track for the record.
I haven't drag race a lot, but a road race start is the same. "Dumping" the clutch is good for slider type clutches and bike with wheelie bars. Other than that, you will either spin badly, wheelie/loop the bike, or bog.
It takes practice of course, and clutch abuse, but for good starts, run the motor up to just under the torque peak at the lights, don't do the "rev, rev,red" as you will never be in sync with the lights. When you take off, roll on the gas deliberately while slipping the clutch holding the rpm at peak torque until the clutch is all the way out. Then shift without the clutch, by super quick backing off and on the throttle and clicking up a gear. DO NOT try and shift the shift lever quickly, like with a stab at it. (you will miss shifts that way) Click up and hold it up until back on the gas.
Here is a vid of the Brit meet from last Sunday, for some reason they love to dump clutches, and you can see the results. Which are not good.
http://vimeo.com/70298073" onclick="window.open(this.href);return false;
