Indicator stems...
pjmcburney
Suzuki 2-Strokes: T20 GT750L RE5A GSX1100S RG500G GSX-R1100N
Indicator stems...
Post by pjmcburney »
Has anyone successfully removed and replaced the stems from the GT indicators?
My RE5 is a US delivered model and consequently has the longer (wider?) stems in the indicators - I'd like to convert them to the shorter style.
I'm forever knocking them moving the bike around (and the shorter ones look better IMO), I have plenty of the shorter Euro stems in my spares stash to swap them out with.
Looking at the way the indicators are put together, it would seem fairly straightforward if the stems aren't pressed in too tight.
Any info greatly appreciated.
Ta
Paul
RING_DING
Suzuki 2-Strokes: 1974 GT750 B-4 (JDM), 1975 GT750M
Re: Indicator stems...
Post by RING_DING »
Paul, I removed the stems from mine and replaced with the shorter ones. It's pretty easy but after you remove the bolt & nut you may need to pry the clamp piece open with a flat blade screwdriver. Don't overdo it or it might break. Couple of squirts of penetrating oil might be need too. Biggest challenge is the wiring. If I recall correctly I think you might have to cut the terminal off to get the wire back through the stem. Other option is to unsolder from the bulb holder end if you want to keep the stock terminal.
You may also find that you need to dress the splines with a needle file for fit, especially if the stems have been re-chromed or are off repro signals - but swapping the stems over is quite doable. 8)
MikeH1A
Post by MikeH1A »
+1 to the above. I redid all the indicators on my GT 750 as they all had crappy or wrong stems. It is just about being methodical and patient. The wiring is a challenge but nothing that can't be overcome. They all work correctly and look the part after being rebuilt. So, go for it
72 GT750J
71 TS250R
71 H1A
pjmcburney
Thanks guys :wink:
I'll give it a go shortly when I get through the other maintenance tasks in my shed :roll:
