buying crank seals
stevebee
Country: australia
Suzuki 2-Strokes: t500 kawasaki z900 harley davidson flsti
buying crank seals
Post by stevebee »
where is a good place to buy seals/bearings/gaskets for my t500?.steve
Bloop2
Country: Ontario, Canada
Re: buying crank seals
Post by Bloop2 »
Crank seals are still available from your local Suzuki dealer, along with all the shaft seals, ie kick starter, gear change, main output shaft, crank bearings O rings etc. Make a list of what you need and check with the dealer first.
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
stevebee
Country: australia
Post by stevebee »
Bloop2 wrote:Crank seals are still available from your local Suzuki dealer, along with all the shaft seals, ie kick starter, gear change, main output shaft, crank bearings O rings etc. Make a list of what you need and check with the dealer first.
thanks :up:
