530 O-Ring chain on a GT750?
- Country: usa
- Suzuki 2-Strokes: 1
Re: 530 O-Ring chain on a GT750?
ahh ok. and there was room still on the outside for that washer to fall into the splined slot?
- Rassie
- Suzuki 2-Strokes: 1973 - GT750
Not sure the, GT750 just has a large nut and the washer is bent over to stop it coming off.
Rassie,
2023 Kawasaki ZX4RR
2019 Yamaha Tracer 900
1972 Honda CB350 Cafe Racer
1980 Honda CX500 Cafe Racer project
1973 Suzuki GT750 Resto-mod project
2023 Kawasaki ZX4RR
- Country: usa
ok... so the models are different there. .... mine has the spocket then a large washer then a tabbed washer that all allow 3 bolts to lock it in place.(no large nut)Rassie wrote:Not sure the, GT750 just has a large nut and the washer is bent over to stop it coming off.
- Rassie
Yep, sure seems that way. My 550 was the same as your picture. Is there threads on the shaft, if so you could possible use a nut and washer. They are still freely available.
Rassie,
2023 Kawasaki ZX4RR
2023 Kawasaki ZX4RR
- Country: U.S.
Holly cow ! That may be the worst conditioned front sprocket I've seen. You have teeth wearing in different directions. Lol !zk0ot wrote:ok... so the models are different there. .... mine has the spocket then a large washer then a tabbed washer that all allow 3 bolts to lock it in place.(no large nut)Rassie wrote:Not sure the, GT750 just has a large nut and the washer is bent over to stop it coming off.
- Country: usa
Rassie wrote:Yep, sure seems that way. My 550 was the same as your picture. Is there threads on the shaft, if so you could possible use a nut and washer. They are still freely available.
i pulled that pic from someone selling it on ebay.zk0ot wrote: no thread just the splined shaft.
- Country: usa
72 gt380 will accept an O-ring chain with no modification.
when i test fit the sprocket and chain. i just pushed the sprocket all the way on and wrapped the chain around it. it rubbed the case.
i realized the sprocket normal goes on. then the next washer slips into the slot (you actually need to turn the washer in the slot to get the holes to line up) . and then pulls the sprocket away from the case as the 3 bolts tighten up.
- Rassie
Aaah, yes I see, very clever. That will have the same result then I assume.
Rassie,
2023 Kawasaki ZX4RR
2023 Kawasaki ZX4RR
- Country: usa
yup pulled the sprocket away from the case with plenty off chain clearance.
- mike1161
- Suzuki 2-Strokes: 1970 T350, 2012 Triumph Thruxton
Well, just to add a bit to this, I'm getting near the end of my restoration for my '70 T350, and without thinking, just ordered a nice 525 size O-ring chain. Tried to fit it last night, and
, the pins just hit the engine case ribs, near the clutch pushrod. I just read the rest of this thread & realized what the problem was, good discussion. Guess the O-ring chains are just a bit wider, due to the O-rings being between the plates & rollers, and they didn't even have O-ring chains back in the 70s. The O-ring chain I had gotten (WPS brand) measured 23.2mm wide at the pins, which is just a hair too wide by the looks of it. Unfortunately, I already got rid of the original chain that was on the bike, so can't measure that. Guess that for now, I'll just order a standard 525 chain and when that wears out I may do a 520 conversion & use an X-ring. Or I could get a 525 X-ring (which from the posts & specs, appear a bit narrower), and maybe put an extra washer between the front sprocket & engine. Anybody done that on a T350?
Current bikes: 1970 Suzuki T350, 2012 Thruxton
Previous bikes: '71 Honda CL350, '82 Yamaha 550 Seca, '86 Yamaha RD350, '88 Suzuki RG500 Gamma, '86 Suzuki VS700, '75 Kawasaki Mach II (S3), '12 Triumph Bonneville T100, '08 Triumph Daytona 675 SE
