The later microfiche only has a part # for the independent type floats....
Ivan
I would buy a pair of them if they are in repairable shape and reasonably priced.tz375 wrote:Early 500s had a wide rounder almost barrel shaped float bowl and the floats had rounded sides and were much wider than the later flat sided floats. Bingo !!
TGrogan was good enough to send me a few carbs to look at last year and he might be persuaded to part with the early type carbs. It's worth asking teh question. I can post pictures of the different floats if you need them.
They do say that there was a 10 fin in this article ? http://www.motorcycleclassics.com/class ... spx?page=2" onclick="window.open(this.href);return false;Ivan wrote:There's no such thing as 10 fins.... Not even on the earilest 500/fives
While tracking engine and frame numbers (which can be found here) as yet we haven't found one - I think it was a reporter's error right from day one and all that's happened is succeeding reporters have just repeated the original misinformation.Suzukidave wrote:They do say that there was a 10 fin in this article ? http://www.motorcycleclassics.com/class ... spx?page=2" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;Ivan wrote:There's no such thing as 10 fins.... Not even on the earilest 500/fives
