I have a question concerning carb jetting. Background info. I bought this 1975 GT550 and knew nothing about 2 strokes really. I installed jemco chambers and didnt change the carb jetting at all. I holed the center piston within 20 miles!!!!!!!
I had the cylinders bored to the first over size piston. I removed the stock main jets which I think were 97.5s on the outside carbs and a 95 in the middle. Installed 110 main jets on all three carbs. The needles are raised all the way up (clips all the way down on bottom notch) and left idle mixture screw at stock setting. The plan was to run rich and work my way down. Well the bike runs pretty well at these settings but it is running pretty rich also. The bike then started running WAY rich when started and was fouling plugs and not running right at all. I bought new plugs and turned the idle mix screws in 1/2 turn each. Runnin like a champ again!!! I was also running the stock air box. I recently put on some pod filters and seems to be running fine with them, although I hear many people reccomend to stay with the stock air box. I also had a guy go through and check the timing. He confirmed everything was set to stock settings.
So, I was thinking of backin down to 105 main jets. I cant help but think the bike would gain a ton more performance by leaning it out a tad. I think at 105s I would still be pretty safe as far as risking another holed piston.
Any info appreciated. What main jets are you running with your chambers?? Sorry if this has been asked 1000 times. I did some reading on here but couldnt find what I was lookin for.
The monster in question. GSXR750 front end, SV650 rear end, jemco pipes, super bike bars.
How she currently runs, sweet music!!
http://www.youtube.com/watch?v=QdQINhv2 ... lpage#t=0s" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
