68" T500 Cobra keys
argo1974
68" T500 Cobra keys
Post by argo1974 »
Hi, I'm in need of spare keys for my Cobra. Unfortunately I couldn't find the #2351 since all T500 iggi switches I've ever seen had 3 digit numbers.
On ebay, I discovered Cobra's steering lock #2353: http://www.ebay.com/itm/1969-suzuki-t50 ... 3a604d49e4" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Therefore I wonder if 4 digit numbers were used on early T500's. The actual key I have has #22 on it.
Any help appreciated.
Argo
1x T500 Cobra (1968)
4x T500K (1973)
Re: 68" T500 Cobra keys
Have a similar situation with my 69 T350. Two digits on the key & 4 digits on the lock. Got another key for the 4 digits via eBay & it works the lock fine.
This eBay seller has 4-digit keys:
http://www.ebay.com/itm/SUZUKI-KEY-KEYS ... 0702229026
They don't list 2351 but list similar numbers. Is your # of 2351 a typo? Also worth double checking the number -- might be easy to misread because of the way it was stamped.
argo1974
Post by argo1974 »
Thanks for the link, I will double check the numbers on ignition switch and ask the seller.
4x T500K (1973)
argo1974
Post by argo1974 »
According to the seller, #22 is a Suzuki key blank number, which was cut to my key number 2351. He's able to copy my key, so problem solved.
4x T500K (1973)
