T 350 pistons/rings/barrels
- Country: NZ
- Suzuki 2-Strokes: T350, 1970 and 1971
Hi all, my 1971 t350 is on the o/size pistons but is pretty worn.
Does anyone have any recommendations for piston replacement or know where a set of std oro/size barrels might be acquired, cheers
- dinogt
- Country: France
- Suzuki 2-Strokes: GT 500
Re: T 350 pistons/rings/barrels
I am trying to do with PE 175 piston (from 62 to 64mm), prehaps it will be... answer in some days...
I don't understand what are "barrels" ?
blue smoke on the horizon
http://www.dinogt.fr
- Country: NZ
The bits with fins on that holds the heads to the cases
- dinogt
- Country: France
Barrels is a slang term for cylinders. Sometimes called jugs.
- oldjapanesebikes
'Pot' is another slang term.
- dinogt
- Country: France
From my understanding, not that it matters I guess, cylinder barrels is the correct and full name, cylinder sleeve is the correct name for the inserts, remember a sleeve can be used for many applications so in our case it is a "cylinder" sleeve, and the barrel is what the cylinder sleeve sits in.
So choke on that
So choke on that
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
"choke on that" or "go enrich yourself". No choke on a GT, it's an enricher...But that doesn't have quite the same punch does it.
On another forum a lot of the car guys refer to the barrels as the "head". Probably because that's where the ports are usually hiding I guess. They're a strange Mob.
- Suzsmokeyallan
Hmmm barrels on cars are usually called "blocks" since it usually resembles a block shape for the cylinder/upper crankcase assembly casted into one piece.
Heads are just that, the cylinder head which is the part of the engine above the head gasket, those car guys you know Richard are a strange and weird mob indeed.
