Strange spark issue, Help please
Brokenarrow
Suzuki 2-Strokes: 97 Tigershark Montego
Post by Brokenarrow »
Issue is with a '97 Tigershark jetski, the engine is a 640cc Suzuki two-stroke. Engine turns over good but will not run on both cylinders. With one spark plug removed (that wire grounded with a screwdriver to the head) it will fire right up and run on one cylinder, same with either cylinder. With both plugs in it will not fire. I checked compression, 115 & 120, I tried different plugs. Will someone please explain to me wth is going on here? I talked to a very good pwc mechanic, he said the cdi ignition system normally either works or it doesn't work at all, (not intermittant).
Jimroid
Re: Strange spark issue, Help please
Post by Jimroid »
I' m guessing dual lead single coil? Both plugs firing every 180 degrees? viewtopic.php?f=29&t=12311" onclick="window.open(this.href);return false; Maybe find a coil, even if primary resistance is not correct, just for a quick test run. You never know!
Try new plug caps.
