V4 RGV500
- Country: England, UK
Re: V4 RGV500
Cool!
- garry55
- garry55
Re: V4 RGV500
taking a break from the 4 strokes, I found time to finally persuade the Ducati 999 steering stem and yokes that they did want to fit in the SRAD steering head..........
then modified the steering lock stops on the Ducati bottom yoke.............
and cobbled together a steering stem nut spanner.............
and that's it until the modified swing arm is returned from the machine shop.
Garry
- garry55
Re: V4 RGV500
The swing arm is back from the machine shop, suitably modified so as to fit the SRAD frame.
Next job was to remove the SRAD's top suspension mounting bracket and make a pocket for the ride height control arm to run in, like so...........
Garry
- garry55
Re: V4 RGV500
then I cut a template for the new suspension upper mounting brackets...........
this was sent away for 2 replicas to be water-jet cut from 10mm aluminium sheet.
and whilst I awaited their return, I made a pair of bearing support brackets..........
Garry
- garry55
Re: V4 RGV500
water-jet cut brackets arrived...........
and with the bearing supports bolted in place...........
Garry
- garry55
Re: V4 RGV500
the brackets, with the bearing supports welded in place and bearings and inner sleeves fitted............
and with the Ducati suspension rocker arm in place...........
Garry
- garry55
Re: V4 RGV500
swing arm, ride height adjuster rod and rear shock installed..........
Garry
- garry55
- garry55
Re: V4 RGV500
tank and race tail in place...........
Garry
