Here i go again ..
Re: Here i go again ..
I so do miss my parts pile .. i mean spare parts supply ...in my garage in Florida , i could hit the garage and find most anything i needed . I know i have 6- '72 intake spickots :? but what i really need is the carb mount attached to the reed cover like this only 3 ... http://www.ebay.com/itm/ARCTIC-CAT-ZR-4 ... cb&vxp=mtr" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Suzukidave wrote:
tz375 wrote:Newtronics is probably the easiest option and you can eliminate a lot of their wiring if you wire it yourself. The harness they ship with is really long. You can also wire it to use stock connector blocks (or replacements at least) for a tidy install.
Problem with that option is i would have to put a stock points side cover back on the engine , with the block centered in the frame it puts that side even more out so with what i have cut off the points side cover it balances the engine width .. problems , problems :roll:
Dave, When you machined off that left cover and removed the points shaft, what did you do to the inside? Is it all hollowed out or was it "sliced off"? It it was just sliced off, it's possible to machine what's left to work like a TR750 inner cover to locate the ignition backing plate.
Modifying a stock cover leaves a few holes that oil mist can escape through, but that's not the end of the world. If it's hollowed out, you can use a trigger wheel attached to the crank and will have to work out a way to mount the pickup. You could probably weld a strip of 1" x 0.250" aluminum to the cover and drill and tap that to support the pickup coil.
That would not work for a Newtronics that needs clean air to work.
I removed the side cover to refresh my mind on just how much i had removed off that points side , it doesnt look like there is any room in there for any electronics :( Image
The wiring system is looking a bit more tidy now with a nice fuse block Image
The original points plate or any replacement ignition will fit over those three bolt holes if they are in the same place as the originals.
Then you need a way to attach the matching trigger to the crank end. You could make up a sleeve nut threaded 10x1.25 at the crank end and 6x1.0 on the outside to take the trigger/rotor.
My side cover is similar to yours but it has been counterbored like a stock cover to provide a place for the points plate to sit.
Or open that up some more and bolt the pickup directly to the machine face or to a plate bolted on the inside
I received a out standing care package of needed parts from list member TZ375 to help me on my way and then went to Ebay and picked up 3 of the needed intakes so i can then fit up the 34mm carbs :up: Image
Now on the hunt for coil wires, caps and plugs .
Technology takes a 40yr step backwards to move forwards :wth: Image
Received the Arctic Cat 440 intakes and they fit right up Image
Next test fit the Arctic Cat 440 ~ 34mm "D" slide carbs .. and they slip right on and in Image Image
water cooled
Post by water cooled »
Dave, your project is really making good progress. Looks great. Wont be long.... :D :D :D
Thanx Kevin , i am working at keeping the ball rolling .. several things on the next list .. 4 into 1 throttle and choke cables and ignition wires and caps .. mount the coils ( somewhere ) :up:
I got my last 4 into 1 cable off ebay. If fact I bought two and they were both different. I did have to lengthen or shorten (I don't recall which) one of them to fit those carbs so get some cable ends from Flanders or MikesXS.
Do you have a cable stop on those crankcases or did you have to fabricate one for the oil pump cable?
I am looking at getting this cable for the throttle anyways http://www.ebay.com/itm/380791685742?_t ... EBIDX%3AIT" onclick="window.open(this.href);return false; ..... i already had a cable mount made up so there shouldnt be a problem mounting the oil pump cable .
Ordered the air filters and the throttle cable Image
