Moderators: oldjapanesebikes , H2RICK , Suzsmokeyallan
Posts: 4317 Joined: Mon Dec 13, 2010 4:32 pm
Post
by jabcb » Sun Jul 09, 2017 2:07 am
Making some good headway.
Cafe-GT250-0392 by
jabcb , on Flickr
Test fit of salty_monk’s adapter + a Kawasaki Concours twin-piston caliper.
Cafe-GT250-0393 by
jabcb , on Flickr
Post
by jabcb » Sun Jul 09, 2017 4:03 am
Test fitting the spiffy new Higgspeeds.
Cafe-GT250-0398 by
jabcb , on Flickr
Post
by jabcb » Sun Jul 09, 2017 4:08 am
New shocks + test fit of rearsets:
Cafe-GT250-0429 by
jabcb , on Flickr
Rearset adapters worked out nicely.
Cafe-GT250-0431 by
jabcb , on Flickr
Post
by jabcb » Sun Jul 09, 2017 4:09 am
Test fit of rearset on other side. Adapter worked out nicely. (The left & right adapters are different.)
The shift linkage rod is for a T500 motor & will need shortening.
Will need the kickstart lever mod.
Cafe-GT250-0432 by
jabcb , on Flickr
Post
Test fit of seat.
Cafe-GT250-0460 by
jabcb , on Flickr
Post
by jabcb » Sun Jul 09, 2017 4:13 am
Slowly making progress. Now has mini gauges & headlight bucket.
Cafe-GT250-0470 by
jabcb , on Flickr
Post
Oh the horrors. Am using an aftermarket Harley ignition switch & bracket.
Cafe-GT250-0474 by
jabcb , on Flickr
Post
by jabcb » Sun Jul 09, 2017 4:14 am
Right-side T500 rearset worked out nicely. Will deal with the rod length after we have the seat on.
Cafe-GT250-0525 by
jabcb , on Flickr
Post
Right side looks good with rod adjusted & brake cable installed.
Cafe-GT250-0528 by
jabcb , on Flickr
Left side will work out too. I modified the shifter shaft adapter — still needs a bit more work. Looks like rod will need shortened a bit.
Cafe-GT250-0532 by
jabcb , on Flickr
Post
by jabcb » Sun Jul 09, 2017 4:19 am
This is the end of the conversion from Photobucket to Flickr.
Post
by jabcb » Wed Jul 12, 2017 7:44 am
Old topic using Photobucket:
viewtopic.php?f=21&t=11918
Front brake installed. Consists of salty_monk’s adapter + a Kawasaki Ninja twin-piston caliper + EBC disk.
Cafe-GT250-0576 by
jabcb , on Flickr
Posts: 3980 Joined: Fri Oct 24, 2008 5:55 pm
Post
by Suzukidave » Thu Jul 13, 2017 4:22 am
Very nice
Post
by jabcb » Fri Jul 14, 2017 12:04 pm
Latest pic with seat mounted.
Cafe-GT250-0579 by
jabcb , on Flickr
Posts: 1769 Joined: Tue Oct 14, 2008 6:47 pm
Post
by rngdng » Sat Jul 15, 2017 6:16 am
I have two of those calipers on the front of my Buffalo. It stops....
Post
by jabcb » Sat Jul 15, 2017 6:56 am
rngdng wrote: ...
Interesting.
Stock, the GT250/GT380 have the small 276mm disks. You use the large 296mm disks with the salty_monk adapter + twin-piston caliper.
Stock, the GT500/GT550/GT750 have the large 296mm disks. What disks & adapters did you use?
