1973 GT250 cafe build - new topic
Re: 1973 GT250 cafe build - new topic
Making more headway.
Cafe-GT250-0294 by jabcb, on Flickr
Cafe-GT250-0295 by jabcb, on Flickr
Cafe-GT250-0296 by jabcb, on Flickr
Mounted new Avon RoadRiders.
Its the third set we’ve done with a No-Mar CH200 tire changer. It has a bit of a learning curve — we are getting faster & got these tires on without marking up the powder coating.
Cafe-GT250-0390 by jabcb, on Flickr
Making some good headway.
Cafe-GT250-0392 by jabcb, on Flickr
Test fit of salty_monk’s adapter + a Kawasaki Concours twin-piston caliper.
Cafe-GT250-0393 by jabcb, on Flickr
New shocks + test fit of rearsets:
Cafe-GT250-0429 by jabcb, on Flickr
Rearset adapters worked out nicely.
Cafe-GT250-0431 by jabcb, on Flickr
Test fit of rearset on other side. Adapter worked out nicely. (The left & right adapters are different.)
The shift linkage rod is for a T500 motor & will need shortening.
Will need the kickstart lever mod.
Cafe-GT250-0432 by jabcb, on Flickr
Oh the horrors. Am using an aftermarket Harley ignition switch & bracket.
Cafe-GT250-0474 by jabcb, on Flickr
Right-side T500 rearset worked out nicely. Will deal with the rod length after we have the seat on.
Cafe-GT250-0525 by jabcb, on Flickr
Right side looks good with rod adjusted & brake cable installed.
Cafe-GT250-0528 by jabcb, on Flickr
Left side will work out too. I modified the shifter shaft adapter — still needs a bit more work. Looks like rod will need shortened a bit.
Cafe-GT250-0532 by jabcb, on Flickr
This is the end of the conversion from Photobucket to Flickr.
Old topic using Photobucket: viewtopic.php?f=21&t=11918
Front brake installed. Consists of salty_monk’s adapter + a Kawasaki Ninja twin-piston caliper + EBC disk.
Cafe-GT250-0576 by jabcb, on Flickr
