Carb Rubber Top
Hustrler T250 72-73
Suzuki 2-Strokes: T250
Carb Rubber Top
Post by Hustrler T250 72-73 »
If the top rubber piece that the sits on top of the carb is cracked at the top will it affect the operation of the carb?
http://www.ebay.com/itm/Suzuki-T20-T250 ... 28&vxp=mtr" onclick="window.open(this.href);return false;
mike1161
Suzuki 2-Strokes: 1970 T350, 2012 Triumph Thruxton
Re: Carb Rubber Top
Post by mike1161 »
I could be wrong, but I don't think this would really affect the operation of the carb in any way. That piece is actually just a dust boot, and if you look at the carb, the screw-on top cap has a rubber gasket that provides a good seal for the throttle slide at the top of the mixing chamber. The fit of the slide in the mixing chamber is pretty tight anyway, so there shouldn't be much, if any, air leaking through the top cap anyway.
tricky1962
Country: United Kingdom
Suzuki 2-Strokes: T500J
Re: Carb Rubber Top
Post by tricky1962 »
I think I'm in agreement with you
viewtopic.php?f=2&t=9150" onclick="window.open(this.href);return false;
But am happy to be corrected by others
desmocat
Suzuki 2-Strokes: T500, TS250, B105P, GS250T
Re: Carb Rubber Top
Post by desmocat »
Trust me it makes a big difference. Having a leaking carb top boot will cause a lean condition, even to the point of a run away idle if the leak is gross enough. I had problems with idling with my '71 T500, replacing the carb top boots remedied the run away idling problem.
Ralph Spencer
Spencer Motoworks LLC
Southfield, MI USA
www.spencermotoworks.com
AHRMA #798
tricky1962
Re: Carb Rubber Top
desmocat wrote:Trust me it makes a big difference. Having a leaking carb top boot will cause a lean condition, even to the point of a run away idle if the leak is gross enough. I had problems with idling with my '71 T500, replacing the carb top boots remedied the run away idling problem.
Good enough for me (reaches for wallet!)
